Hi Everyone, I have purchased dummydata v2 from the store, it installed fine, visible in the container (I bashed into it), conf.php has the right settings for external modules, yet I do not see the installed module in the dolibarr web interface. I will attach some screenshots. HELP would be appreciated.
Can you ask the author that the module is compatible with v20 ?
Hi and thanks for replying. It says it is compatible, and the previous version of the same author recommends this version for v20. I emailed the support email but no response yet.
I thought I would ask the community to see if anyone else had a similar experience.
Actually, my mistake. The module states ‘up to 20.0.1’. I have 20.0.2 installed. I’ll mark this as solved and await an email from the author. Thanks again.
20.0.2 is just a bug fix maintenance version compared to 20.0.0 and 20.0.1. So if it works with 20.0.1 it should work with 20.0.2 too
