Duplicate entry '1' for key 'uk_societe_code_clien
Dear All,
I face this problem while uploading data in third party (company info),kindly advice me as once i upload i get duplication issues
* Line 2
> Duplicate entry ‘1’ for key ‘uk_societe_code_client’
* Line 3
* Line 4
* Line 5
* Line 6
* Line 7
* Line 8
* Line 9
“s.code_client” should not be the same in first line and the others.
It seems that you defined “s.code_client” in all lines as “1”.
thanks a lot for the information , but i failed to see that s.code_client is it in th kindly database or the import format kindly tell me where i can edit it so that i can finish this.it has been days with such a problem
thanks
It is in the fifth cell of the import format - Customer code (s.code_client).
thanks but i have given different codes 0E to 144E etc
i dont think i put same number check the attached doc which i failed to import it in my system,
Be sure that comma (,) is just there when needed in import file.
which coma ? I still face same problems
* Line 2
> Wrong value for field number 24 (value ‘’ is not a value available into field code of table Company types)
> Wrong value for field number 31 (value ‘3/27/2013’ does not match regex rule ^[0-9][0-9][0-9][0-9]-[0-9][0-9]-[0-9][0-9]$)
* Line 3
> Mandatory data is empty in source file for field 3.
> Mandatory data is empty in source file for field 4.
* Line 4
* Line 5
* Line 6
* Line 7
* Line 8
* Line 9
* Line 10
* Line 11
* Line 12
* Line 13
* Line 14
* Line 15
* Line 16
* Line 17
* Line 18
* Line 19
* Line 20
* Line 21
* Line 22
* Line 23
* Line 24
* Line 25
* Line 26
* Line 27
* Line 28
* Line 29
* Line 30
* Line 31
* Line 32
* Line 33
* Line 34
* Line 35
* Line 36
* Line 37
* Line 38
* Line 39
* Line 40
* Line 41
* Line 42
* Line 43
* Line 44
* Line 45
* Line 46
* Line 47
* Line 48
* Line 49
* Line 50
* Line 51
There is still 298 other source lines with errors but output has been limited.
Date should be written like this: 2013-27-03 and in the import document there should be no "
Delimiter between columns should be comma.
Any luck?
already try, all above,
but the solution it seem to empty the field 5,
it works for me
:cheer: :cheer:
I also have this issue. Unable to import field with existing company code. Can import OK without code which is field 5. Its a real nuisance.
