Hello Everyone,
I’m currently trying to replicate an existing Dolibarr setup that was running on a Windows 10 HP laptop (using XAMPP 7.4.2). I have copied all the Dolibarr files and moved them to a Proxmox 8.3 LXC container running Debian 12. The goal is to perform a fresh installation of Dolibarr 11.0.0 in this new environment.
However, I’m stuck at the following installation step and can’t proceed:
/dolibarr-11.0.0/install/step2.php
Installation Page:
Dolibarr install or upgrade - Database objects creation
Server connection: localhost
Database version: 10.4.32-MariaDB
Database name: dolibarr
Despite the database connection being successful, the installer does not proceed to the next step.
Original Environment Details (Windows 10 XAMPP):
- Apache 2.4.41
- MariaDB 10.4.11
- PHP 7.3.15 / 7.4.2
- phpMyAdmin 4.9.4
Current Environment (Debian 12 LXC on Proxmox 8.3):
- MariaDB 10.4.32
- Apache (Debian default)
- PHP 7.4.x (installed manually to match compatibility)
The database is reachable, and user permissions are correctly set. I even tried using both a root and a dedicated Dolibarr user. Still, the installer is stuck at step 2.
Has anyone experienced a similar issue or can suggest what might be causing the installation to hang at the database objects creation step?
Any help would be appreciated!
