Multi Price - Products Module
What is the use of the Multi Price option available on the products module?
I have now been using Dolibarr for the past 7 months and have always entered 2 prices for each product:
  1. Retail 2) Wholesale.
    But to date I have not managed to make use of the 2nd price as this would not show up in invoices or pos. I would have to first to add the item with price 1 and then adjust the price manually.
Any advice?
Mutliprice depends on customer.
You define 2 prices. Then into customer card, you define what is price for this customer. Then when creating invoice, proposed price will be one defined for customer.
:blush: that simple…stupid me never realised :unsure: …
thanks eldy!
eldy wrote:
How does it works? After enabled I see no option to set customer prices into “customer card”. Instead I have five prices levels and that’s all. On the other hand, the “suppliers card” works perfect with the option to add specific prices for each supplier.
Any advice? :dry:
Onto the customer tab, you should see a property “Price level”.
Set the level for this customer. Correct price will be sued according to level. (1, 2, 3…)
Oh I see, thanks for the response… by the way, is there a way to bulk update price levels, let’s say in a percentage basis or something similar?
Hello
I am trying to find this functionality in Version 6.0.2 but unfortunately I cannot find it.
Is there a way to activate multi pricing in 6.0.2?
Regards
Cedric
I found it myself. go into the product module settings and change the “Rules for sell prices”.
