I have the problem that the average price per product changes if I
- add 4 pcs @6.22050
- remove this 4 pcs at this price
- add 4 pcs again at 6.22050
the avg. price becomes 6.21437?
The routine is as follows:
// we can not left join above because if no stock we would not receive the warehouse rowid!
// so extra query to get stock in this warehouse
$sqls = "SELECT reel as stock FROM ". MAIN_DB_PREFIX. "product_stock WHERE fk_entrepot = '".$rowe['rowid']."' AND fk_product = '".$object->id."';";
$results = $db->query($sqls);
if (! $results) {
dol_print_error($db);
exit;
if ( $results->num_rows == 1)
$rows=$results->fetch_array();
print " ".$lagerarr[$lrec]['arnr']." STOCK ALREADY in Dolibarr deleting ".$rows['stock']." #sql#".$sqls."\n";
// subtract the full stock in dolibarr to be able to readd with correct average price
$object->correct_stock(
$fuser,
$rowe['rowid'],
$rows['stock'],
'1',
'Löschen Lagerbestand für Reimport des Bestandes mit korrektem Preis',
$lagerarr[$lrec]['durchschnittlicherek'],
null,
'0',
null
// CAREFULLY! If stock in dolibarr already exists and is different then current, subtract full
// stock and readd full stock and price. otherwise the average price would change.
// AVG CHANGES ???????
$fuser,
$rowe['rowid'],
$lagerarr[$lrec]['lagerstand'],
'0',
'import',
null,
'0',
null
