The project overview doesn’t show (or compute properly) the manufacturing orders amounts. The raw material and finished products used are properly configured in terms of prices. The manufacturing price is calculated correctly in the MRP module. The manufacturing orders references are listed in the project overview but with 0 amounts.
It appears that this problem exists in the V15, V16 and V17 versions of Dolibarr.
Dear all,
are you experiencing the same problem ? I have tried on two different servers with the same result = manufacturing amount not shown in the project overview.
Can anyone help please ?
The only solution, without modifying the code, is to perform the calculation outside Dolibarr using a BI tool. Dolibarr developers must integrate this cost using MO data of reel prices of quantities consumed. Else the project will not reflect reality.
