I submitted the following Bug to Dolibarr ERP & CRM on GitHub.
I just wanted to share this issue here to bring awareness.
Variable Substitution - Project Variables Not Working
Bug
The following variables do not work in email templates.
__PROJECT_ID__
__PROJECT_REF__
__PROJECT_NAME__
Environment Version
13.0.1
Environment OS
Ubuntu 18.04.5 LTS
Environment Web server
Apache/2.4.29 (Ubuntu)
Environment PHP
PHP 7.2.24
Environment Database
MariaDB
Environment URL(s)
/admin/mails_templates.php
Expected and actual behavior
The following Variable Substitutions are not populating the Project Emails as expected:
__PROJECT_ID__
__PROJECT_REF__
__PROJECT_NAME__
When using any of the above variables, the email message body just prints their key.
Example of variable in an email message:
The expected behavior would be:
Print out the Project id for __PROJECT_ID__
Print out the Project ref for __PROJECT_REF__
Print out the Project title for __PROJECT_NAME__
I am pretty confident that the following lines in htdocs/core/lib/functions.lib.php
never get hit:
if (is_object($object->project))
$substitutionarray['__PROJECT_ID__'] = (is_object($object->project) ? $object->project->id : '');
$substitutionarray['__PROJECT_REF__'] = (is_object($object->project) ? $object->project->ref : '');
$substitutionarray['__PROJECT_NAME__'] = (is_object($object->project) ? $object->project->title : '');
if (is_object($object->projet)) // Deprecated, for backward compatibility
$substitutionarray['__PROJECT_ID__'] = (is_object($object->projet) ? $object->projet->id : '');
$substitutionarray['__PROJECT_REF__'] = (is_object($object->projet) ? $object->projet->ref : '');
$substitutionarray['__PROJECT_NAME__'] = (is_object($object->projet) ? $object->projet->title : '');
I will note that even though the following code does not exist in htdocs/core/lib/functions.lib.php
, it will print out the expected values in Project emails when they are added outside of the conditional blocks for if (is_object($object->project))
and if (is_object($object->projet))
$substitutionarray['__PROJECT_ID__'] = $object->id;
$substitutionarray['__PROJECT_REF__'] = $object->ref;
$substitutionarray['__PROJECT_NAME__'] = $object->title;
Steps to reproduce the behavior
Create a project email template with any of these variables:
__PROJECT_ID__
__PROJECT_REF__
__PROJECT_NAME__
Send a Project email using the email template.
No response
I have a workaround until the Dolibarr Admirals come up with a patch to address the bug I found.
Following the documentation for Other personalized tags
I created a new file in htdocs/custom/emailnotifications/core/substitutions/ called functions_emailnotifications.lib.php
Inside the functions file, I created the following function called emailnotifications_completesubstitutionarray
in my custom module called EmailNotifications.
/** Function called to complete substitution array (before generating on ODT, or a personalized email)
* functions xxx_completesubstitutionarray are called by make_substitutions() if file
* is inside directory htdocs/core/substitutions
* @param array $substitutionarray Array with substitution key=>val
* @param Translate $langs Output langs
* @param Object $object Object to use to get values
* @return void The entry parameter $substitutionarray is modified
function emailnotifications_completesubstitutionarray(&$substitutionarray,$langs,$object)
global $conf,$db,$object;
$emailnotification_project_id = isset( $object ) && isset( $object->id ) && ! empty( $object->id ) ? $object->id : '';
$emailnotification_project_ref = isset( $object ) && isset( $object->ref ) && ! empty( $object->ref ) ? $object->ref : '';
$emailnotification_project_title = isset( $object ) && isset( $object->title ) && ! empty( $object->title ) ? $object->title : '';
$emailnotifications_substitutionarray['__emailnotification_project_id__'] = $emailnotification_project_id;
$emailnotifications_substitutionarray['__emailnotification_project_ref__'] = $emailnotification_project_ref;
$emailnotifications_substitutionarray['__emailnotification_project_name__'] = $emailnotification_project_title;
if (!is_object($outputlangs)) $outputlangs = $langs;
$substitutionarray = getCommonSubstitutionArray($outputlangs, 0, array(), $object);
$substitutionarray = array_merge($substitutionarray, $emailnotifications_substitutionarray);
Then in htdocs/custom/emailnotifications/core/modules/modEmailNotifications.class.php
I enabled substitutions:
$this->module_parts = array(
// Set this to 1 if module has its own substitution function file (core/substitutions)
'substitutions' => 1,
Now I can use the following custom Variable Substitutions in my email templates and print out the expected values in the Project emails I send:
Here is an updated function: smaller and cleaner:
// If $object IS-A Project provide substitutions
if (is_object($object) && get_class($object) === 'Project') {
I decided to stay with the original naming conventions, so that in the event that they get fixed, then we don’t have to go and update all the email templates to take on the fix.
Instad of
I’m using
__PROJECT_ID__
__PROJECT_REF__
__PROJECT_NAME__
